Pairing touch keys
Ane
Pairing touch keys
My touch keys are not paired to my Px6 and I can't figure out how to do it.
Holyoblation
Re: Pairing touch keys
Same here. Controls for my px6 2013 f150 are wrong and won't learn whether or not wheel setting is set to protocol or learn
My PX6 has a menu to map the keys. My menu is the last tab in the settings. I can map the buttons on each side of the screen.
LeadByIntegrity
Have you tried plugging the two wire from the steering wheel harness to the red and black plug off the unit? There are two separate connections that come off as a Y, if one doesn't work the other will. But to be honest, I didn't even need that wiring harness. As I also tried my steering wheel functions with my OE harness and everything worked.
Best wishes.
Best wishes.
