Phoenix Android Radio Backup Camera Not Working?
Posted: Thu Jan 21, 2021 8:04 pm
Ensure that the proper video cable labeled "back up" is connected to the correct female video cable on the back of your unit. If your camera is not firing when you put your car into reverse, ensure the wire for triggering the backup camera is soldered to the correct flying lead on your Phoenix Android unit.
If you are using an OEM camera, ensure you have set it correctly in the Advanced Settings on the Phoenix Android Radio unit if it has not been set already.
