Phoenix Android Radio Backup Camera Not Working?
- phoenixgod
- Site Admin
- Contact:
Ensure that the proper video cable labeled "back up" is connected to the correct female video cable on the back of your unit. If your camera is not firing when you put your car into reverse, ensure the wire for triggering the backup camera is soldered to the correct flying lead on your Phoenix Android unit.
If you are using an OEM camera, ensure you have set it correctly in the Advanced Settings on the Phoenix Android Radio unit if it has not been set already.
madmat
Re: Phoenix Android Radio Backup Camera Not Working?
I have a 2010 Ford f150 LARIAT. is the OEM camera supported by my px6-six-core-pre-order-12-1-inch-vertical-screen-android-8-1-navigation-receiver-for-2009-2014-ford-f-150?
Ive tried all the settings and it doesn't seem to work.
JimDixonIII
What is the correct setting?If you are using an OEM camera, ensure you have set it correctly in the Advanced Settings on the Phoenix Android Radio unit if it has not been set already.
snystrom
