HELP!
Car: Mustang 2014 digit clima
I have to reset the PX6. After the reset the AC control button missd. I see only the bluetooth statos (Connected or not). Now I cant control the AC.
What I have to do now?
How can I set back the previus version?
Mustang 2014 AC control buttons missing
Deanrsnowiii
Re: Mustang 2014 AC control buttons missing
first check in your settings and make sure ac information is switched to on.
if not its likely this scenario...
so usually what happens is when you reset you unit, you reset the base android and must reinstall your supporting apps.
easiest way is to download TOTAL COMMANDER from the play store. then you can access all of your factory apps saved upon your device in a system folder.
from there you will find several system apps needing reinstalled.
