Anyone using Sergey's custom firmware?
Anyone use this custom firmware (I understand it's paid custom) for Phoenix Android Radios? Wondering about success stories anyone had. Sounds promising.
Custom firmware for Android 4.4.4 and 7.1 with 1024x768 display
1. Support for Live wallpapers (some themes are with transparent background)
2. Fixed layout for popular themes – without overlapping or breaking words.
3. All themes are unlocked – more than 20 themes available
4. You can change themes without enter password from passwordless page.
5. Added Cruiser theme (I can add Tundra to lower bar).
6. For some models fixed outside T problems.
7. Corrected “while list” to listen music with most popular apps.
8. Added 2 new themes for Radio, Music Player and Bluetooth (modern and black)
9. Music player changes:
a. Correct sort of loading files
b. Real random mode – song will be repeated only after half playlist played,
c. If You listen more 5 second and click Previous, You will go to beginning of song, not rev track.
d. Mute wheel button is paused/unpaused playing.
e. Some layout fixes.
10. Radio click on Favorite station also highlight same Freq in full list and versa.
11. Bluetooth:
a. You can set value for volume when You answer the call. After answer, the volume will be setting to this value. When hang up, the volume is restored to last value.
12. Mode wheel button switches between radio, music player, online player only. If you start Navi, navi will be switched too.
13. Add radio-button at setting to adjust up/down (forward/backward) wheel buttons.
14. Added swap-file to improve stability and fastness.
15. New file manager in black style.
16. Custom back track lines (colors, You can move ‘em to fit your car dimensions).
17. Now You can choose online player from setting. Some themes has button for it at upper bar. Correct pause, continue playing after sleep mode.
18. You can control Air by wheel buttons. Just press MUTE button and You got it..
Custom firmware for Android 4.4.4 for 1920x1080 displays
3. All themes are unlocked – about 10 themes available
8. New Climate panel style (Black with Land Cruiser)
11. Bluetooth:
16. Custom back track guidelines (colors, You can move ‘em to fit your car dimensions).
carter242000
Re: Anyone using Sergey's custom firmware?
Post by carter242000 »
Yes I am on 2 different px6 9.0 units. Well worth the $100. Highly recommend. Great support also.
AutoKnob
Post by AutoKnob »
why would anyone pay 100$ for firmware that the radio should already have? This radio is almost useless. It doesnt do a dam thing right
