Honda Accord Gen 7 steering wheel controls
Posted: Mon Feb 08, 2021 10:02 am
I recently installed the Phoenix Automotive 10.1 inch large screen Android unit into my 2005 Honda Accord (Gen 7).
The install was relatively easy, other than the supplied connector for the AC unit was not needed (I assume this is only needed if the Honda does NOT have dual AC controls?)
The steering wheel controls, however, do not work. I can't figure out why since this should be pins 3 and 5 on the Blue connector and everything else on that connector seems to work fine.
Has anyone else had this issue?
