2015 Silverado ac barely cooling
Luluspiers1
After installing the new radio my ac is barely cooling. Where as before it would freeze you out. It is a 2015 Silverado and I already talked to support on the matter and all my settings are apparently right.. has anyone else had a problem with it not cooling very well?
Deanrsnowiii
Re: 2015 Silverado ac barely cooling
Luluspiers1 wrote: Sat Sep 03, 2022 12:44 am After installing the new radio my ac is barely cooling. Where as before it would freeze you out. It is a 2015 Silverado and I already talked to support on the matter and all my settings are apparently right.. has anyone else had a problem with it not cooling very well?
it would seem to me its not controlling your A/C and heater HVAC blending doors. Can you hear your A/c compressor under the hood turn on? can you hear an audible sound when switching between warm and cold in the sound of the air.
Thanks
