PX6 - 17” Toyota Land Cruiser 200 - 2008
When I open the doors, the indication is wrong way around.
When I open the left door, it shows the right door is open, when I open the right door, it shows the left door is open.
How do I, fix this?
Door Indication - Problem
RiverCake
Re: Door Indication - Problem
You need to go into user settings - or the "install set" a few below.
Is your steering wheel on the LHS or RHS?
There is a setting for that - it looks like the Chinese programmed for both types. You need to select the correct orientation first.
Then - if it is setup correctly for you - and the door animation is still wrong -
Scroll down to "Door Position" or something similar - you need to simply click Positive or Negative from what I remember.
