Fix: Phoenix Android Radio AC Not Working
Posted: Tue Jan 19, 2021 8:24 pm
by phoenixgod
For 7.1 Android OS Unit
Try to set to 19200 and 38400 with the Protocol XinFeiYang
For 4.4 Android OS Unit
Settings, System Vers/Info, Press and Hold middle of screen - Keypad will come up - 7890 ok, System, can scroll down to the setting below.
After set to XFY, 38400, 38400 need to restart by pressing the RST button with paper clip near the mic.
or turn off car, open close door, turn car back on
Phoenix Android Radio Ac Not Working
Phoenix Android Radio Ac Not Working (107.36 KiB) Viewed 16764 times
For 7.1 Unit
check settings
advanced (8861)
car type
Old F150 Lo (For Manual AC)
Old F150 Hi (For Auto AC)
press one of those 2 car types
Then on the next page, check that
Protocol is - Xinfeiyang
check mark the box at the top right of the picture
press ok
then restart the unit
If AC Controls has
Temperature Control and On and Off Control
Try Re connecting OEM unit - Set the Air conditioning Fan to Low
Re Plug our unit then see if AC controls works
Re: Fix: Phoenix Android Radio AC Not Working
Posted: Mon Jan 25, 2021 8:25 am
by tstumph
I recently bought a Pheonix PX6 Six-core 12.1" Android 9 Fast boot Navigation Radio for a 2007 Lexus ES350. After I hooked it up, the AC controls and the OEM backup camera was not firing when I put the car in reverse. I went into Settings>Install Set (code 8861), selected my vehicle model and set the protocol to "BNR with AC", saved and rebooted. It fixed both of those issues. Hopefully, this may help someone else.
Posted: Mon Jan 25, 2021 10:03 am
by phoenixgod
tstumph wrote: Mon Jan 25, 2021 8:25 am I recently bought a Pheonix PX6 Six-core 12.1" Android 9 Fast boot Navigation Radio for a 2007 Lexus ES350. After I hooked it up, the AC controls and the OEM backup camera was not firing when I put the car in reverse. I went into Settings>Install Set (code 8861), selected my vehicle model and set the protocol to "BNR with AC", saved and rebooted. It fixed both of those issues. Hopefully, this may help someone else.
Thank you for sharing this.
Posted: Mon Apr 12, 2021 1:11 pm
by TylerCapozzi
Tried this. Had a totally different passcode. and now no volume works.
Posted: Sun Jan 30, 2022 7:22 pm
by Alvzl14
I'm been having the same issue for over a year now and no one could even help me with mine. I been on remote help calls even no one could fix it. I had to leave my existing ac unit plugged in just so I can have air or heat. What is funny is that the head unit still see that I'm using my air because it shows up on the screen but when I try to touch a button nothing happens
